Results 1 to 2 of 2
Thread: Any body used Torque model EQ Ratio adjust B3005 in E92 ?
    May 2010
    Default Any body used Torque model EQ Ratio adjust B3005 in E92 ?
    I did not understand the benefit from this table but i noticed some E92 will not
    follow the commanded AFR so could this table correct this problem ?
    Thanks in advance
    EFILive Tuner
    Apr 2007
    Have tuned about 10-12 E-92's ---Haven't messed with B3005 at all as I'm not quite sure what it will actually do or over-ride
  1. E40 stock throttle body to 102mm, what table to adjust
    By smooth01 in forum Gen IV V8 Specific
    Last Post: January 15th, 2015, 01:25 AM
  2. final drive ratio 1.0 corvette issues changing gear ratio
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: October 6th, 2014, 11:24 AM
  3. Any body have E92 stock file ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 16th, 2013, 10:31 AM
  4. E92 Not being supported yet?
    By 05gmcsierra in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
  5. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
