Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: CM2200A Cummins Questions
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Default CM2200A Cummins Questions
    Was Cruising through things and noticed that there was a patch for the RSA Security for the CM2200A. Got one sitting here(2011), haven't even tried hooking it up to the V2 yet, but whats the process for reading out the truck? Can we read out the stock file like normal? and then apply the RSA bootloader patch, then flash over the stock/modified tunes that we read off the truck? or do we need to find some other method (like the LML or getting a dealer reflash) for acquiring another stock file that can be flashed in after the RSA patch?
    If I can get a read out without the rsa patch, then ill run outside and grab a read off the truck and mail it in, seeing that there isn't calibration support as of yet. Just curious. Haven't really dug into it yet as Ive been busy with the LMLs.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    Senior Member WyoFreeride's Avatar
    Sep 2011
    The patch is for the 601 boot block. It fixes the anti tuning boot loader.
    Last edited by WyoFreeride; November 1st, 2014 at 02:39 AM. Reason: Didn't know what I was talking about
    2010 Dodge QCSB 6.7 Auto
    Dec 2012
    I was just reading the "Cummins 6.7L Bootloader RSA Patch User Guide" is all. Don't really know a whole lot about em ATM.
    " Supported Vehicles
    This guide documents the patching process for:
    1. Cummins CM2100A (2007-2010) ECM’s
    2. Cummins CM2200A (2010-2012) ECM's (tuning support presently not available) "
    That is what I was basing my assumptions off of.
    Josh
    '04 GMC LLY
    Sep 2011
    Sorry. You are right. Too late, brain fart. 2100 is what I meant. 2200 you can't read or tune yet.
    I hope the fact that its in the manual means its close. I almost fell out of my chair when i read that the first time.
    Also, v8 scan will detect a 2011 but can't scan anything yet and no pids are available
    Quote Originally Posted by Chavez91 View Post
    We can't get reading working via OBD-II yet
    But the Bootloader patch has been developed and tested working here on the CM2200 (so yes we can flash them too), I guess you can see that the CM2200 is in the pipeline given we can get around the anti-tuning stuff.
    Before anyone asks on the 2013+ CM2350B, no luck there, the Bully Dog box seems to be a good solution and probably the only option.
    Dec 2012
    Ahh... Alright! Sounds good! Hopefully you get it soon!
    Good work! On the RSA!
    Josh
    '04 GMC LLY
    May 2008
    I talked to someone at Ennis this fall at their booth and he said they used the Bully dog to unlock the ecm and then used something else to tune and in some way delete a 13'+ cummins. he said the only way available was to ship the ECM to them, they tune it for 1500.00 and ship it back overnight.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    They (Bully Dog) came up with something better than that, they used to have people send the ECM in but now they have a module that programs via a different CAN port (not via the OBD-II plug) where I guess the anti-tuning checks are not applied, nothing like leaving the door accidentally wide open Cummins. Hats off to Bully Dog on that one, keeps the aftermarket alive.
    Dec 2012
    Yeah. They have a $50 module that you can use with the gt tuner that plugs into a plug in the engine bay that is integrated into the flash process. It's a one time use tho. Once you use it and unlock the ecm. It's unlocked. You don't need to use the special box ever again for that truck.
    Josh
    '04 GMC LLY
    May 2008
    So then what can we use to do the tuning? Or would it be another bully dog tuner?
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  1. New 5.0L cummins
    By LORDDiESEL in forum General (Diesel)
    Last Post: August 21st, 2013, 10:57 AM
  2. 2012 Cummins
    By joelapi in forum Cummins 6.7L
    Last Post: April 12th, 2013, 06:38 AM
  3. V2 '03 Cummins
    By SRXtreme in forum FlashScan V2
    Last Post: January 21st, 2012, 09:29 AM
  4. Have the v2 for gm how to get for cummins?
    By kregelsmax in forum Purchase and Shipping
    Last Post: December 26th, 2011, 05:04 PM
  5. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 08:06 AM
