Nope. It requires the GT tuner. the box is just additional hardware needed. The device by itself doesn't do anything.
Josh
'04 GMC LLY - L5P, Motech, 6-Spd Conv. ML Trans.
'05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
'19 3500 RAM - Tuned Aisin 0_o
Ok I see
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
Not sure we'd be the first, didn't H&S have 2013+ tuning done too?
Definitely not going to commit anything in writing at this stage.
It can't be done, simply impossible unless you get Cummins to sign the digital signature for you (never would they!)
It is a pain but think of it like this, a new RAM is around $55K right, an extra few hundred bucks here and there to tune it isn't much in the scheme of things. Remember BD was the first to unlock these but it required you to send the ECM in to them and cost around $1,200 from memory, so already with the new arrangement they have you are in front.
Ive never seen anything for 13's from H@S. I think it would ahve come out on the down low by now if they did.
2003 Jetta TDI,
1986 K10 LQ4/4L80E
Oh ok, must have been 10 - 12 then, I wasn't sure if they had done it before the issues they got caught up in.
Yep. torque tech is close to tuning the 13's too i understand.
2003 Jetta TDI,
1986 K10 LQ4/4L80E
No disrespect to them, but Who?
I think he means torquetech.ca?? Just did a quick Google search.. never hear of then either...
Josh
LOL yeah thats who I mean I've used a couple and they work good. not near the features of an H@S but does the job.
2003 Jetta TDI,
1986 K10 LQ4/4L80E
I'm sure unlocking could be done though the obd port. right after you figure out the RSA string.
time frame wise I think that'll be right after Jesus's second coming.
BD unit seems to backdoor the RSA and switch it off without actually figuring it out. Be nice to know what it is actually doing and if same is possible on LML dmax.
