Results 1 to 3 of 3
Thread: BAD PCM input?
    Apr 2006
    Default BAD PCM input?
    My TCC brake switch input (pin 33 purple if I am not mistaken) is reading 10.4VDC with the wire isolated and ignition on or car running. The scan shows this input "Applied" could this input be bad?
    Is my only course of action to get a new PCM? This is causing my cruise to lock out. This is a new swap and the car drives fine and I guess the PCM is compensating for this input being bad. I have yet to get the cruise to work and I installed the Corvette drive-by-wire system.
    Any ideas?
    Using a 1k resistor on the end of the wire, short it to ground and then to 12V, and each time see if you get any change on the scan tool.
    If you get no change, then unplug the PCM connector(s), locate that wire's pin, and test the wire's continuity with a multimeter (may need a buddy to hold one of the probes); also check for short to power and to ground.
    If continuity is good and wire is not shorted, inspect the PCM connector plug/socket for damage or foreign objects.
    If that seems ok, then PCM may have a bad input.
    It won't hurt to check the ground to chassis connections in engine bay.
    Apr 2006
    Default Problem solved
    I found the problem. The TCC Brake Switch input was on pin 34 and it should have been on pin 33. I moved it to the proper pin and the cruise control worked perfectly.
    Just a simple mistake from the harness builder, who by the way helped me solved this issue.
  1. stft (your input)
    By drdarthinvader in forum Custom Operating Systems
    Last Post: April 23rd, 2010, 10:49 PM
  2. Input Plugs
    By RyanU in forum External A/D inputs
    Last Post: September 4th, 2008, 06:30 AM
  3. BB ExtAD input to AFR
    By Garry in forum FlashScan V2 BB Logging
    Last Post: May 14th, 2008, 02:49 AM
  4. V2 input/output pin out
    By horsepower in forum FlashScan V2
    Last Post: January 2nd, 2007, 01:16 PM
  5. V2 and 12v input
    By kbracing96 in forum General
    Last Post: December 7th, 2006, 05:38 PM
