Results 1 to 10 of 11
Thread: Saved tune in v8 now won't load in v7
    Senior Member djv86's Avatar
    Nov 2014
    Default Saved tune in v8 now won't load in v7
    I downloaded a tune from a stock lmm 2007 and wanted to open it up in the v7.5 tune program just to snoop around and it won't even find the file to open it.
    Is there a program or converter to allow the tunes saved in a v8 to beable to be loaded in the v7.5?
    Do you have matching installs for both V8 and V7 ? In otherwords you can't have an old version of V7 installed if you have a newer version of V8.
    Nov 2014
    They are both that I downloaded from efi website
    Nov 2014
    Anybody know why I downloaded a lmm diesel tune using v8 saved it and it will not open in v7.5 it actually won't even pop up in the folder as if it was wrong file type
    You downloaded it as in 'read from the truck' or a file you found on the internet?
    Is the file type .tun or .ctd or .ctz...?
    Nov 2014
    I downloaded and saved it from the vehicle itself. I'll let you know file type it saved as in a few mins when I arrive to work
    Nov 2014
    Saved as a .tun
    Nov 2014
    Sorry it saved as a .ctz
    You will need a later version of V7 tunetool... try this: Update-Oct-5-2014
    ( you will need to updater both V7 and V8... and also V2 firmware... and also V2 BBx configuration )
  1. Viewing saved log in the V2 possible?
    By Highlander in forum FlashScan V2
    Last Post: March 26th, 2013, 09:38 AM
  2. Replies: 4
    Last Post: March 5th, 2012, 03:54 PM
  3. Tunes won't load
    By Grinchanderson in forum Duramax LB7
    Last Post: October 3rd, 2011, 01:50 PM
  4. Help! trying trying to load tune
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 25th, 2011, 07:10 AM
  5. Saved tune file
    By RedBowTies88 in forum Cummins 5.9L
    Last Post: January 27th, 2011, 03:46 AM
