Results 1 to 5 of 5
Thread: LC1 serial AFR
    Dec 2008
    Default LC1 serial AFR
    I have used TAQ cables serial connection fine before its setup correctly via the tutorial. If using Logworks at idle im reading 14:7 just fine Logging in EFIlive scanner KOEO my external WB shows a default 25:00 when I start the vehicle it drops to 4.7 like im missing a 1 in from of it I don't know what I did or how to correct it to show correctly in the scanner. I tried looking for the config.ini file in EE and it was not there could this be the issue??
    Dec 2008
    Ok I fixed it somehow the LC1 was programmed with lambda even though ive owned it since new an have never changed any settings. Fixed with the LM2 programmer software changed to gasoline setting what threw me off it was registering AFR logging serial to log works.
    LC-1/LC-2/LM-1/LM-2/MTX serial comms:
    - lambda is logged as is;
    - EQR is loggeds as is (i.e. 1/lambda);
    - AFR is lambda x stoichAFR;
    I have found that sometimes my LC-1 "forgets" the stoichAFR.
    Nov 2006
    use lambda/eq with a calc_pid for afr
    this will always be consistent.
    LC-1 WBO2
    Dec 2008
    Thanks for the tips
  1. serial lc1 calibration? Please Help
    By EVI in forum FlashScan V2
    Last Post: April 12th, 2009, 01:26 AM
  2. LC1 serial to V2
    By nonnieselman in forum FlashScan V2
    Last Post: November 12th, 2008, 01:58 PM
  3. Need Help w/LC1 Serial Logging
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: August 4th, 2008, 02:35 PM
  4. 2 LC1's via serial link?
    By Neptune in forum Black Box Logging
    Last Post: June 18th, 2008, 08:27 AM
  5. LC1 Serial Logging
    By oztracktuning in forum General
    Last Post: November 8th, 2005, 05:45 AM
