Results 1 to 10 of 13
Thread: backfire
    Sep 2013
    Default backfire
    hi all,
    I have put an ls2 with ls3 square port head and a cam in my Nissan patrol. the engine is brand new and never been started before.
    i am using an ls1 pcm and efilive v1.2
    when i tuen the engine over it goes to start but won't run and i am getting backfiring back through the intake.
    what could this be? timing? tune?
    could low fuel pressure do it? i am using brand new fuel pump i ordered however i put a gauge on the fuel rail and it is only showing 40 PSI pressure
    any ideas would be greatly appreciated.
    thank you very much in advance.
    Sep 2013
    is there anyway to convert and e40 or ls2 tune for the ls1 pcm?
    which tune should I use I noticed I can download different tunes from the file depot
    im in aus by the way.
    I just need to get this up and running, it is going to be dynotuned.
    Do you know if the LS2 engine's crank/cam reluctors are 24x/1x or 58x/4x...?
    ( remove the CKP sensor and peek inside...
    if you see a single reluctor wheel with evenly spaced teeth then it's a 58x;
    if you see dual reluctor wheels (which appear to be the inverse of each other) with unevenly spaced teeth then it's a 24x;
    Is it an early (24x/1x) or later LS2 (58x/4x)...?
    40 psi rail pressure is too low... it should be 58 psi.
    Sep 2013
    Sorry I should of mentioned.
    Im using the conversion box. German name starts with l
    Sep 2013
    Yes I have a feeling the guy I got the fuel pump off ordered the wrong one
    And you need the correct FPR (58 psi with reference hose removed).
    Quote Originally Posted by lbheart View Post
    You mean the LPE 58x/4x -> 24x/1x converter
    ( LPE = Lingenfelter Performance Engineering )
    Sep 2013
    Yes that is the one I am using.
    I modified my fuel tank (welded plates in the top) so they take the self regulating commodore pump so I only need one fuel line up the the engine bay. I must have the wrong ones because im only getting 40 psi instead of 58
    Sep 2013
    I have two fuel tanks each with their own delphi fuel pod and independent fuel line up to the engine bay
    Sep 2013
    Maybe there is a way to modify the ones I gave to pump at the correct pressure. The way it works is the fuel is pumped in a loop down at the fuel tank and this loop is at pressure so u T off that loop to get fuel at pressure to goto your fuel rail
  1. Backfire, then ESP light
    By Chevvy SS in forum Gen IV V8 Specific
    Last Post: September 1st, 2011, 03:02 PM
  2. a little backfire issue
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: February 3rd, 2011, 12:08 AM
  3. Please help tune out backfire
    By LS1-450 in forum Gen III V8 Specific
    Last Post: May 4th, 2009, 01:24 PM
  4. BackFire / Flames
    By meshoooo in forum E37, E38 & E67 PFI ECM's
    Last Post: October 3rd, 2008, 06:42 AM
  5. Backfire Problem?
    By WS600 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 1st, 2008, 09:06 PM
