Results 1 to 10 of 16
Thread: Find that timing retard!
    Sep 2012
    Default Find that timing retard!
    Trying to understand where the timing went to on the launch, around frames 2265. It went to zero. Traction was an issue so I was pedaling the car, but I still don't understand why the timing went as low as it did. Traction control on the car was turned off, ignore the burnout as I did forget to turn traction control off there. Tune and log attached.Log_10-3-14_track4.efiturbo tune_60lb injectors_CLfulltune2.ctz
    Sep 2012
    My initial thought was DFCO was kicking in since it was large throttle and then let off and then back on, but there are map and other restrictions on DFCO before it actually kicks in.
    Lifetime Member limited cv8r's Avatar
    May 2005
    Try logging some of the spark pids in the scan tool to try and see what is pulling the timing.
    It's all good until it goes "Bang"
    Sep 2012
    It's not my car so I can't just log it whenever. I was hoping it would be something obvious in the tune that I am just missing. On launch it starts to wheel hop so we had to pedal it and its seems like the frame after we're high tps% and then let out before getting back on the gas, it drops timing to nothing. Hence, the thought of DFCO or something else that would do that.
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Not looking at the tune or log. But have you checked knock? Burst knock can do some dumb stuff, also if it's an auto check torque management. How much timing is being pulled?
    Sep 2012
    Quote Originally Posted by picnic_george View Post
    Zero knock and burst knock table is set to pull zero degrees. Car is an M6. From what I gather, the car was pulling somewhere between 6-8 degrees. Initially I saw the timing was going to single digits and realized it was in the high g/cyl low rpm area of the main octane spark table. I fixed that and now it still seems to be dropping to zero if its peddled. If you floor it from a 1mph rolling start so it doesnt wheel hop, then we dont see the timing drop.
    Jan 2007
    Not jumping back into the base(idle) spark table is it? Sorry I can't view it, just trying to help you find the problem.
    Sep 2012
    Worst case timing in the base table is 17*. It feels like a Cat Over Temp or something stupid like DFCO. Are you not able to view the tune because of the SW version you have or is my attachment not work?
    Jan 2007
    I'm not on my tuning computer.
    Sep 2012
    I gotcha. Thanks for your help anyways.
  1. B5156, do i really need 20* of timing retard ?!
    By skneeland in forum Gen IV V8 Specific
    Last Post: April 10th, 2012, 10:16 AM
  2. need to retard timing under boost
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 8th, 2008, 01:07 AM
  3. Timing retard
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 09:25 PM
  4. Nitrous timing retard
    By PRAY in forum Gen III V8 Specific
    Last Post: December 12th, 2007, 05:49 AM
  5. 4 degrees timing retard needed
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2006, 01:42 AM
