Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Flashing MIL after 24x conversion
  1. #21
    Aug 2012
    I'm aware of that and I don't think it would run so great if they were crossed. Cyls 2 and 3 are also swapped and they don't produce any misfires.
  2. #22
    Aug 2006
    Ya, I didn't see your other post until after I commented. The only reason I brought it up is that I have seen other people not have the firing order correct on the 24x deal.
    Jeff
  3. #23
    Aug 2012
    I just changed the misfire tables of the 5.3 to match my old 5.7 tune. I'm hoping they are just false misfires (I can't feel them). The 5.3 has smaller values in the tables and has a greater range of them. Maybe the 5.3 misfire table is fine tuned to its cam profile (114lsa compared to the 111lsa of the Vortec 5.7)? But only misfiring in two cylinders and not all of them? But cylinders 4 and 7 are references from the same spot on the reluctor wheel, correct?
  4. #24
    Aug 2006
    Quote Originally Posted by bubba68ss View Post
    Cylinders 4 and 7 are references from the same spot on the reluctor wheel, correct?
    I don't think so. 4 and 7 are not companion cylinders.
    PS: Your gas gauge doesn't work, correct?
    Jeff
  5. #25
    Aug 2012
    I was thinking of the firing orders
    18436572 5.7
    18726543 5.3
    Two crank revolutions to light all cylinders and cyl 7 fires on the third quarter of full crank revolution. Cyl 4 fires on the same spot next time the crank goes around. Same spot on the crank is initiating that spark, right?
    Pcm thinks it's firing cyl 7 but inj and coul are wired to cyl 4. Same goes with cyl 2 and 3.
  6. #26
    Aug 2012
    Quote Originally Posted by Lextech View Post
    Jeff
    Funny you mention that, since the conversion whenever I brake hard or turn corners my fuel gauge has been dropping to empty and then it slowly notches it's way back up. What made you point that out?
  7. #27
    Aug 2010
    ... What made you point that out? ...
    The commonly used switch for the PCM PWM output to the fuel gage is disabled in the tune that you posted. Most Vortec (Black Box) PCMs have this output enabled .... most LS1-B PCMs do not.
  8. #28
    Aug 2012
    Interesting. Fuel gauge works fine. Just now and then it will go to empty on decel but then come back up
  9. #29
    Aug 2012
    Now that I have this conversion done and everything seems to be running smooth (misfiring sorted out, just bumped the mid values about 75%), can I now run the 5.3 spark tables since I am (assuming) capable of a little more timing with CNP setup?
  10. #30
    Aug 2006
    Does your gas gauge work properly now?
    Jeff
  1. Efi 24x Conversion Startup Issues
    By jahajazz in forum Gen III V8 Specific
    Last Post: December 16th, 2012, 05:20 AM
  2. Replies: 25
    Last Post: May 28th, 2010, 01:12 PM
  3. 24x conversion questions
    By monzaaddict in forum Conversions / Aftermarket Parts
    Last Post: July 5th, 2009, 12:11 PM
  4. flashing MIL?
    By Thimble in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 01:44 PM
  5. MIL for a LS1 conversion
    By Biggsy in forum Gen III V8 Specific
    Last Post: April 7th, 2007, 05:44 PM
