Any issues with this cable?
Anything I should be aware of?
What should i look for if I buy?
What should be included?
TIA
TIA
Basically all you need is the actual FlashScan cable and the blue registration (license) card that would have come with the product to the original owner.
You may want to check the number of available licenses. If there are none you will need to purchase VIN licenses at US$99 each.
And, perhaps also which edition it is. If it is Personal you will not be able to use Custom OS's because it does not have the full flash capability required to update the OS portion of the PCM. This can however be upgraded for a small US$150 (well worth it IMO).
That is about all I can suggest...
Hope that helps.
Andrew
EFILive Crew
No problem.
Hope you get it for a good price. It is definitely the best software I have seen. And better still is the support of the EFILive team (Paul and Ross) and the members on these forums.
Andrew
EFILive Crew
Ended up buying from Green Light Motorsport. Excellent transaction and experience.
A good friend Bruce Melton convinced me of the merits of EFILive. Green Light Motorsports was the icing on the cake.
LOL. Yes, Chad a good friend of mine. I actually setup and host his website
Did you get one of the combos with the wideband sensor? They are a must IMO.
Andrew
EFILive Crew
