Just curious if there was a way to enable high idle while also having the csp5 switch?
I believe I have seen a place in the program for high idle. The weather here just became cold enough that my truck will high idle in the morning without any changes in efilive.
07 dodge 2500 5.9 cummins, 2inch level, modified air box, deleted exhaust, Efi live tuning, borg warner gov. Solenoid, billet transmission, 35 inch terra grapplers
22 ram 2500 6.7 6 inch lift 22x12 welds, 37x13.5
You can't enable high idle, you'll need a base file that has it enabled
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Is a csp5 tune or calibration available to enable the high idle? Its unlocked with the stock tune just not when I switch to my csp5 tune
If it's enabled in your stock tune and your using your stock tune as the base file that your upgrading to csp then it should still work.
Les Szmidt
2007 5.9 Dodge Ram
