Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 01 lb7 dmax..... cant pass 480 rwhp on the dyno.
    Apr 2014
    Default 01 lb7 dmax..... cant pass 480 rwhp on the dyno.
    I built a dsp5 tunes for a customer his truck has stock injectors stock turbo fass150. he has dynod 480 rwhp at h&s dyno. I am trying to get the truck to hit 500+ hp. I do have the tune avaible if sum one wanna take a look at it it is on 35's crew cab long bed. his best pass at the track is 13.2
    Lifetime Member Mitco39's Avatar
    Jan 2009
    hows the rail pressure? if its holding just turn up the fuel a little, should be enough for a 20hp boost. Also what boost are you seeing? stock wastegates suck.
    Apr 2014
    it holds max rail pressure still. but has stock fuel pressure table in it. max boost we are seeing on the insight monitor is 23psi of boost. he does have the mbrp down pipe intake heater deleted on it. I have about 3050us on injectors with 28degrees of timing. just stumped with it. he has a stage 5 ppe trans in it. we did the ii injector cups and arp headstuds in and the trans.
    Jan 2009
    The insight is not good at monitoring boost unless your have the expandable sensors installed. I would suggest a real boost gauge (or get the extender for the insight) Or if you have a way of monitoring boost directly on the dyno that would also be preferred.
    Hows the smoke under load? if its dirty all the way through then you need more air to make more power. Running out the injectors much past where you are now wont gain you anything but heat, especially if your dirty up top as it is.
    Apr 2014
    from a stop to about mid range its smokey and clears up but still a lil haze at the end of the track egts are 1600.
    Apr 2014
    when dynod last it was 100% load on the dyno and it blacked out the dyno room lol over at h&s
    Jan 2009
    Id take a closer look at your boost. Sounds like you have plenty of fuel and I wouldn't go to much higher on the WOT timing unless its your truck and your aware of what could happen.
    Apr 2014
    the truck belongs to a good friend of mine and he is aware of it. this truck is out in Utah. we are trying to hit the 500 hp mark. would u say the boost table will need to have the boost coming on sooner in it?
    Jan 2009
    LB7s don't have boost control tables. Its all mechanical. If the stock wastegate isnt holding its own thats holding you back.
    Apr 2014
    ok thanks buddy. so need to check to make sure the wqastgate is doing its job or being lazy and opening up when it shouldn't. would taking the b0748 table on the lower rpm and about mid fueling up to 100% fueling to about 2600 rpm and set it to 0 help spooling the stock charger more as well.
  1. Can´t get idle ls3/480
    By Bert-Ola in forum Gen III V8 Specific
    Last Post: April 29th, 2014, 02:16 AM
  2. e67 ls376/480
    By rapidgb in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 05:13 AM
  3. LS376/480 and 6L90
    By 55chevdelray in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 11th, 2009, 09:42 AM
