Originally Posted by
bballer182
How did you make a custom pid? i'm trying to do something simialar to that but i'm trying to figure out how to do a instant fuel econ. and a custom one to get actual boost which would be turbo boost minus baro. any suggestions?
Did the boost one a while ago (my first calc pid actually )
Edit the calc_pids.txt in the My Documents\V7.5\User Configuration\
If its not there add it.
Boost calculator
Code:
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
*CLC-00-000
psi 0.0 10.0 .0 "({SAE.MAP}-{GM.BARO})*0.145"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.BOOST F600 CLC-00-000 "psi" Air "Boost pressure"
Does like you said. KPA - BARO and then convert to PSI
Jez
