Results 1 to 8 of 8
Thread: 1998 Corvettte cold start issue (MAF DELETE related?)
    Apr 2013
    Default 1998 Corvettte cold start issue (MAF DELETE related?)
    I received a 1998 corvette with not 3-4 in a 60e, I pulled the trans and rebuilt it, no issue, the customer then wanted to fix his cold start issue
    I Pulled the tune(no MAF on the car) and started to look at it...
    During a LOG the commanded desired airflow is at 0.00!!! and only runs when i give it throttle until 99degreesF then rpms jump up as desired airflow is now reading 2-3 grams/sec. In the tune there is 3-4 grams/sec under 100F ECT, but I cannot understand why it isnt trying to add throttle by itself...Electronic Throttle should be the "IAC" correct?
    I have noticed the speed density tune was somewhat incomplete, I set the p0101, p0102, p0103 to non emmisions, but it didnt help...do i need to get a custom OS in it???Is one even availiable for a 1998 car?
    thanks for any help tips or tricks.
    Is the MAF physically missing...?
    Do you have any logs of the cold start...?
    Apr 2013
    Yes, Maf is gone and they cut the pigtail connector off, I can run another log and save it..
    Quote Originally Posted by Brad Kimbler View Post
    Did they leave the IAT wires connected...?
    Apr 2013
    Yes sir, I wasn't watching it to see the value, I'll double check to see if its reading but it was in the intake
    Apr 2013
    I got a cold start log, added a few pids I think might be helpful, Notice the desired airflow is 0.00 until 99F ECT, thats where rpms jump up ...during the 99F and colder are I have my foot on the gas pedal, when it hits 99F it will idle without my foot on the pedal , I also noticed the OL to CL mode happens at 92F ECT , not sure if its related?
    Mar 2011
    Your B4307 looks like it needs to be lowered by 50%
    Lifetime Member limited cv8r's Avatar
    May 2005
    Here is a File from Tune file depot, maybe do a compare and see if there is anything obvious to you, or try the stock tune in vehicle and see how it runs.
    It's all good until it goes "Bang"
  1. IAT related issue?
    By Operator62 in forum Cummins 6.7L
    Last Post: April 10th, 2013, 12:17 PM
  2. E40 Cam Cold Start issue........help please!!
    By quik95lt1 in forum Gen IV V8 Specific
    Last Post: December 19th, 2011, 03:31 AM
  3. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  4. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  5. LS7 MAF related question....mind as well start!
    Last Post: June 7th, 2006, 09:34 AM
