Results 1 to 6 of 6
Thread: WTB - LM2 to V2 cable
    Junior Member clubby5000i's Avatar
    Jul 2007
    Default WTB - LM2 to V2 cable
    Hi all,
    just seeing if anyone has a innovate LM2 to V2 cable for wide band logging? I know I can make one, but just seeing if someone has a cable they don't use anymore. Shame the old TAQ cables are not in business anymore. I tried FISH also, but they don't sell them anymore either.
    Cheers
    Leppy
    Dec 2014
    I need one too! haha
    Jul 2007
    I ended up making one SuperSlow. Pretty easy when you find the right wires! Some of the instructions I found showed the wires in 2 possible positions, but its easy once you track the wiring.
    Cheers
    Leppy
    Dec 2014
    Quote Originally Posted by clubby5000i View Post
    Cheers
    Leppy
    Awesome man, good to know. Did you use the accessory cable they sell?
    Jul 2007
    I used the innovate cable (part # 3812). It has the 4 pin molex connector that plugs into the LM2, and the radio jack at the other end. I cut the radio jack plug off, then used a standard telephone cable (RJ12) and joined the wires together. If using a RJ12 connector, be sure to use a 6 pin plug - that's where my first test failed. I used a standard RJ12 with 4 pins and it didn't connect, as you need position 1 in the RJ12 6 pin plug. There's some great info in one of joecar's threads on here including pictures and diagrams. Once ytou know how to do it, you could make one in about 5 minutes.
    If you get stuck let me know.
    Cheers mate
    Leppy
    Dec 2014
    Thanks a lot and will do!
  1. LM2 to FSV2 cable?
    By sparkinak in forum FlashScan V2
    Last Post: June 13th, 2014, 10:40 AM
  2. LM2 Analogue
    By lq9nissan in forum External A/D inputs
    Last Post: July 11th, 2011, 03:33 PM
  3. LM2 question
    By Eric in forum Gen III V8 Specific
    Last Post: September 26th, 2009, 09:59 AM
  4. LM1 vs LM2
    Last Post: August 26th, 2009, 05:45 AM
  5. Anyone tried the LM2 already?
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: August 6th, 2008, 01:04 PM
