Page 13 of 13 FirstFirst ... 3111213
Results 121 to 122 of 122
Thread: 2010-2015 Cummins Tuning Support moves into Beta
  1. #121
    Nov 2005
    From today's newsletter...
    Fleece Performance Engineering in conjunction with EFILive is pleased to announce a solution to switch off the Anti-Tuning measures for 2013-15 Cummins 6.7L ECM's. This solution eliminates the need to purchase additional hardware that will be used 'once only' to unlock the ECM prior to custom tuning.
    This ECM unlocking service, offered exclusively through Fleece Performance requires users to remove the ECM and send it to Fleece Performance for their same day unlock service. The ECM unlocking service will be available from February 16, 2015, and is priced at $250.00 plus shipping.
    All 2013+ (CM2350B) Cummins ECM's have been manufactured with very high level of anti-tampering security and require security manipulation before custom tuning can commence. Extensive joint development between Fleece Performance and EFILive delivers this unique unlocking service. All methods previously used to get around this type of tuning protection via the OBDII port do not work on the 2013+ ECM.
    This joint project is the only solution EFILive will implement as custom one off hardware not suitable for end users has been developed. For further details on this ECM unlock service please visit Fleece Performance.
    Cindy
  2. #122
    Dec 2011
    edit found my answer
  1. Tuning for the 2010-2013 Cummins
    By MAXX IT OUT in forum Cummins 6.7L
    Last Post: August 13th, 2013, 04:42 PM
  2. Help with TCM tuning on 2010 LMM code says doesnt support A50
    By darins28 in forum Allison 5 & 6 Speed
    Last Post: April 24th, 2013, 12:27 AM
  3. Offer to be a 2010+ Cummins EFI beta tester.
    By someguy in forum Do you want to be a Beta Tester?
    Last Post: January 23rd, 2012, 11:33 AM
