Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 122
Thread: 2010-2015 Cummins Tuning Support moves into Beta
  1. #11
    Nov 2005
    Quote Originally Posted by BigCE View Post
    Will we need to unlock a 2013+ ECM before we can flash it with efi live? Or is the software capable of doing that already?
    Yes, the ECM needs to be unlocked first either by cracking open and hot wiring the ECM, or by using a product like the BullyDog unlock.
    Cheers
    Cindy
  2. #12
    May 2008
    So with the BD unlock can it be used more than once or is it a one time one per truck use?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  3. #13
    Member mpdtune's Avatar
    Jul 2013
    Quote Originally Posted by catman3126 View Post
    As many trucks as you want right now. You have to do the full unlock process, load the bullydog tune file, then flash back to stock with the bullydog. That leaves the ECM in a tuneable state and the Bullydog unlocked for another truck.
  4. #14
    Dec 2012
    Estimated price
  5. #15
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Quote Originally Posted by mpdtune View Post
    I had heard that the unlock process can only be done once per tuner, after that it is still unlocked to flash any other supported vehicles but cant be used to unlock any additional ecms.
    Do you have experience that says otherwise?
    2010 Dodge QCSB 6.7 Auto
  6. #16
    Jul 2013
    Quote Originally Posted by WyoFreeride View Post
    As far as I know it will work. The unlock cable is only needed once and can be used on multiple trucks (I've done this). I have one that I've done an unlock with already I'll have to try on another truck.
  7. #17
    May 2008
    It looks like one has to have the gt tuner also with the unlock cable?
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  8. #18
    Senior Member DieselMafialb7's Avatar
    May 2012
    Unlock cable is one time use only
  9. #19
    May 2008
    But the gt tuner is multiple use?
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  10. #20
    Dec 2014
    Is this going to be like the lml where we don't get access to the dtc list?
  1. Tuning for the 2010-2013 Cummins
    By MAXX IT OUT in forum Cummins 6.7L
    Last Post: August 13th, 2013, 04:42 PM
  2. Help with TCM tuning on 2010 LMM code says doesnt support A50
    By darins28 in forum Allison 5 & 6 Speed
    Last Post: April 24th, 2013, 12:27 AM
  3. Offer to be a 2010+ Cummins EFI beta tester.
    By someguy in forum Do you want to be a Beta Tester?
    Last Post: January 23rd, 2012, 11:33 AM
