I had this problem before, and solved it, but it's back and I can't figure it out. The car will idle fine when it's stopped. But as soon as I'm moving, and push the clutch in or go to neutral, the car will idle between 1500-2000RPM. And it doesn't seem to do it all the time, just most of the time. I can't seem to find the table that would affect this. I can drive my idle air flows wayyyy down and get it to work, but then it also tries to die, and totally screws up the idle when parked. I have a 2001 Corvette Z06 with a C5R 427 motor. Which tables should I start with????
Thanks,
Derrick
