Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: need help on making better lower end response.
  1. #11
    Aug 2014
    I think you might want to look at your main injection timing. It is way too low in the lower end. IMO there is no reason for negative timing at all. I bet this truck is a smokey mess at low throttle and can definitely see why there is no low end power. I'm far from an expert so I'm not trying to be rude or anything this just stands out to me the most.
    Also I would fix your throttle "position to desired fuel" F0505 and F0508 just make them linear across the board. For your injectors you might have too much pilot as well and I would advance the timing of the pilot about 2 degrees across the board.
    I have attached one of my tunes I made for my buddys 06 5.9 its bone stock just as a comparison I think it can help you see what I'm getting at. Look at my timing calculator vs yours.
  2. #12
    Senior Member tylerltr450's Avatar
    Aug 2014
    Quote Originally Posted by BigCE View Post
    why did you cut post injection and cut out pilot after 2400?? Just curious i seen this before and are you doing this to start the computer to use main timing instead?
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
  3. #13
    Aug 2014
    Quote Originally Posted by tylerltr450 View Post
    The computer always uses "main" timing, pilot timing is degrees before main timing not from TDC but "X" amount before main injection.
    In my experience they respond better to only one injection event the best at higher rpms to make peak power. I usually dump it off after 2400-2600rpm ish, you cant even tell its gone unless you are free reving it in park. Then I just focus on the one event. This isn't a max effort tune keep in mind, its a strong tune but not everything its got strong. If I had to guess 125hp ish I dunno.
  4. #14
    Aug 2014
    Interesting. Im gona have to try and write something up with that and see how the truck likes it.
    I always use the full maps but always looking at something different.
  5. #15
    Apr 2014
    I will take a look at ur tune as comparison to mine bigce
  6. #16
    Feb 2012
    I do not post much but I will try to help you a bit here. I also made a couple changes to your tune and will send it back to you. Your boost fuel limiter will need a little work, also you have a awful lot of main us for injectors that big. I would pull back to the 2200-2400 range and slowly move from there. I made changes to your base timing table only you might try that and see how it runs. Take a close look at limiters you have quite a few places that could use some work. For example you are commanding more timing than you have your limiter set to allow, there are also some fuel limiters that could use some work . I changed your boost equivalence table a bit , you will see it in the file I send you. Keep on making small changes and you will figure out what works for your set up and what does not.
  7. #17
    Apr 2014
    with that pulse width I had in that tune. what u think hp wise it could have made?
  1. Getting KR at lower cruise speeds.
    By willn in forum Gen III V8 Specific
    Last Post: September 6th, 2010, 02:45 AM
  2. lower/eliminate TC functions.
    By acomp917 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 23rd, 2010, 09:28 AM
  3. How would you lower LTFT 5% across the board
    By nitrorocket in forum Gen III V8 Specific
    Last Post: November 26th, 2009, 02:34 PM
  4. Need to lower EGT's
    By sweetdiesel in forum General (Diesel)
    Last Post: July 29th, 2006, 02:09 PM
  5. Lower the CR and you should adjust...
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2006, 03:45 PM
