Hello all, new member here. I have a 95 silverado with a turbo lq4 6.0 (yea I know, great starting platform). Details are front mount 76mm turbo, ZO6 cam and springs, 72lb injectors at 4bar, cobalt SS map sensor, switched over to COS3 with speed density.
Basically it wont run. When I start it it idles low and rough and then dies. Smells like its running pig rich and I took out a plug and it was wet.
Now the strange part is that it will run (somewhat) on a previous tune that was done from PSI harness when they reflashed my PCM for the 6.0. Its a stock style tune (no COS) with incorrect injector values and the stock MAP sensor put back in.
Heres my current tune, the best running tune (psi harness), and a stock tune. I know you guys like looking at the tunes and a log but could I still do a log if it doesnt run? Thanks for the help.
6.0 turbo Custom OS current tune.ctz
LS1B 6.0 turbo PSI harness tune.ctz
Stock 6.0 Litre (12208322) Original.tun
Now I read some of the open loop tuning threads and applied that to the current tune but I dont know if Im just digging myself a bigger hole.
