Results 1 to 9 of 9
Thread: 2012 Camaro Mangacharger Cam And Exhaust - Check this tune
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Default 2012 Camaro Mangacharger Cam And Exhaust - Check this tune
    Mods
    -MagnaCharger 3-6 pulley
    -Custom Ground CAM (Getting Card from speed shop)
    -Valve Springs
    -Pushrods
    -ARP Balancer Bolts
    -Stainless headers
    -Stainless mid pipe
    -Stainless SLP Cat Back System
    -McLeod RXT Clutch and Flywheel
    -TR6 Spark Plugs
    -SLP cold Air intake
    Only has 4000 miles on it.
    Cant believe I'm buying it for such a steal.
    Dyno Papers show 544Hp 500Tq
    Tuner Dyno tuned it with HP tuners... Never got the cam specs from him
    Arrival Tune.ctz
    I don't know much about those polynomial VE tables.
    Any suggestions or things you guys notice let me know...
    Post some log files.
    VVE: see this thread (latest files at included in post #80): E38-VVE-Setup-Guide
    Nice car, 544 RWHP, enough to kill evil tires
    What injector does it have...? Can you obtain the various data for those injectors...
    Mar 2011
    Thanks I'm sure that the injectors are whatever ships with the Magnuson supercharger really wish I knew what the cam specs wer it is quite aggressive
    Mar 2011
    What should i log the next time i go for a drive.
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Not going to thread jack, but do they still recommend de-pinning the MAF to enter SD even if you plan on going back to the MAF? Some say yes, some say it's a waste of time.
    I'm satisfied that if a MAF DTC is present there is no need to unpin the MAF (or otherwise physically remove it)...
    but, you can do several experiments to show you what happens:
    1. without a MAF DTC, set the MAF table(s) to zero, see if engine runs or not.
    2. cause a MAF DTC to occur, and set the MAF table(s) to zero, see if engine runs or not.
  1. 2012 Camaro V6
    By Rhino79 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 13th, 2013, 01:55 AM
  2. 2012 ZL1 Camaro Tune
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 11th, 2012, 03:33 AM
  3. anyone have a base tune for mangacharger?
    By blackc5ls1 in forum Gen III V8 Specific
    Last Post: August 27th, 2009, 09:00 AM
  4. Cam I Tune A 97 lt1 camaro with efi live
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: January 12th, 2009, 05:22 AM
  5. 2000 Camaro Head and cam tune file.
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2007, 11:10 AM
