Originally Posted by
Brad Kimbler
Its hard to get a firm or hard 3-4 shift, I usually build 3-5 4l60es a month for 10-11 sec cars as well as stock builds..I totally block off the 3-4 accumulator and DOUBLE the valvebody feed, this makes it noticeable, but still not hard to bad whatsoever. As far as the tune...Turn it up in my opinion...If I'm doing a stock truck with stock trans tune, I will usually highlight the entire 4th gear shift table and add 10-20 at least, even on my built transmission, its not a hard shift...Just make sure you DO NOT have the converter locked during a shift..most OS prevent this from happening but I have seen it able to lock during a 3-4 shift and that's very damaging to the trans, most of the time your better off eliminating 3rd gear lockup anyway. As far as billet servos...eh...I favor the corvette second gear servo and stock 4th gear servo . The stock 4th gear servo is plenty IF the mods are done during as build as I mentioned, or if you go into the tune and add to that 3-4 shift table. Oh and as far as maxing the shift table out, I wouldn't do that, just add to it, if the pump sees too much pressure to often the pump rotor has been known to crack preventing any movement. Now if you pull the trans andf add a billet pump rotor...go for it..
