Results 11 to 20 of 24
Thread: 4l60E 4th shift pressure 96PSI
    Jan 2013
    Here is the stock TCM file for my 07 TahoeAttachment 17808
    Keep in mind this is a 6000LB SUV with a 4l60E and a 5.3 .
    Take a look at (D8301) 3>4 Shift Pressure it is all 90 and the (D3104) 3>4 Torque reduction is 0. (D3101) 3>4 Shift Time is 0.0. Don't pay any attention to the other shift times, as this is a soccer Mom SUV.
    The Base Pressure for the 3>2 downshift (D8203) is set at 90 across the board also.
    Quote Originally Posted by bmc1025 View Post
    How does the 3->4 shift feel at low/mid throttle...?
    The stock truck 4L60E did not have the larger area 2nd servo, so that's one way to provide sufficient clamping.
    Jan 2013
    Believe it or not it is not harsh at all. It must be restricted in the VB. The 3>2 shift is harder, but I would describe it only as almost firm.
    I would assume this is actually a 4L65E or 4L70E but I have not had one of these exact transmissions apart. I also think you are correct about the 2nd servo piston. My wife's s-10 has the larger servo and 2nd is much more firm, shifting up and down. I have to use a little TR to soften the shift at lower throttle.
    Apr 2013
    Its hard to get a firm or hard 3-4 shift, I usually build 3-5 4l60es a month for 10-11 sec cars as well as stock builds..I totally block off the 3-4 accumulator and DOUBLE the valvebody feed, this makes it noticeable, but still not hard to bad whatsoever. As far as the tune...Turn it up in my opinion...If I'm doing a stock truck with stock trans tune, I will usually highlight the entire 4th gear shift table and add 10-20 at least, even on my built transmission, its not a hard shift...Just make sure you DO NOT have the converter locked during a shift..most OS prevent this from happening but I have seen it able to lock during a 3-4 shift and that's very damaging to the trans, most of the time your better off eliminating 3rd gear lockup anyway. As far as billet servos...eh...I favor the corvette second gear servo and stock 4th gear servo . The stock 4th gear servo is plenty IF the mods are done during as build as I mentioned, or if you go into the tune and add to that 3-4 shift table. Oh and as far as maxing the shift table out, I wouldn't do that, just add to it, if the pump sees too much pressure to often the pump rotor has been known to crack preventing any movement. Now if you pull the trans andf add a billet pump rotor...go for it..
    Jan 2013
    Quote Originally Posted by Brad Kimbler View Post
    It is already maxed out from the factory in the Tahoe.
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    1-2 is easy to get a firm crisp shift.... 2-3 is harder to accomplish. 3-4 you can make noticable but not crisp.
    I think the size and weight of the vehicle is a contributing factor as well.
    1-2 will slam even with Tq Management and the stock pressure tables.
    2-3 i start at somewhere arround 25 PSI and work up to max 96 by arround 275flbs
    3-4 is maxed at 96 PSI all the way across
    What about 13 vane rotor? Im not running the stock 10 vane.
    Apr 2013
    Quote Originally Posted by HellKnightHicks View Post
    13 vanes are worse about breaking, the extra vanes are slots in the same diameter rotor as a 10 vanes, so 3 more slots thin out areas on the rotor...The main stress point is converter installed depth not being deep enough into the rotor, also running a extra quart low or over filled as welll can cause pressure spikes, damaging the rotor...this is not a super common failure..over the past few years I have seen 4 broken stock rotors, one of those being my build, this is why i only do performance builds with billet rotors now.. I'm not trying to make anyone paranoid, just trying to help give 60es a good name ...Click image for larger version.
ID:	17812Click image for larger version.
    Mar 2011
    Circle D torq converters come with a kit to make sure that you properly shim the TC into the tranny.
    Most everybody seems to hate 4l60e's I got 222000 out of mine in my white truck... In my blue one i got around 200,000 before it blew... Not a bad tranny... Coolers really seem to help them stay alive... even those little dinky stock coolers make one heck of a difference.
    But you gotta either build it yourself or find someone who is good with trannys... Preferably local.
  9. #19
    Mar 2011
    Would be nice to be able to control the down shift pressure but the Express Van OS doesnt have a table for that... The only thing thats close would be the temp adjust.
    Wonder if it cold be indirectly controlled from thoes temp adjust tables.
  10. #20
    Jan 2013
    If I had some free time I would hook up my gauge and test it out. It will be a while before that happens though. Is any of your down shifts too soft?
  1. 4l60e Problem with TCC lockup in 4th below 39mph with a vacuum modulated valve body
    By sac811 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 9th, 2013, 03:54 PM
  2. 4L60E WOT shift 1>2
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2012, 07:08 PM
  3. 4l80e 4th gear and tcc problem (running from 4L60E segment)
    By kkustomz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 28th, 2011, 02:05 PM
  4. 4L60E shift points
    Last Post: April 28th, 2010, 02:37 PM
  5. Basic Tune 4l60e Pressure Tweaks?
    By therock in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2009, 09:51 PM
