Idk really havent checked them to be honest.
I have a pressure gauge on mine.
She hits 250+ on the 3>4 shift or while the TCC is locked sometimes.
If you're putting an appreciable level of torque (above 400 ftlb) and/or you're spinning the engine higher than stock (~6000 rpm) then the 4L60E needs various internal upgrades (the transmission thread at LS1tech has some good threads on which components)...
with these upgrades, various people have got good results, but it does take knowledge/experience as Brad's info above indicates.
Has a full HD-2 Kit with the high rev release spring set.
5 pinion planiteries
Beast sunshell.
Z-Pack
500 Boost Valve
Sonnex OD servo
Vett Servo
Full HD-2 Maxxed out
