Results 1 to 10 of 11
Thread: Afm ( active fuel management ) aka d.o.d.
    Senior Member djv86's Avatar
    Nov 2014
    Default Afm ( active fuel management ) aka d.o.d.
    using the efi scan tool and commanding the A-D solenoids on and off one cylinder has a noise as if the lifter has an issue with latching and unlatching.
    my question is does anybody know which solenoid is for which cylinder ?
    wiring diagrams show pin location at the VLOM is A-E
    A-cylinder 4
    B-cylinder 6
    C-cylinder 1
    D-cylinder 7
    Im unsure if thats how EFILive is using to figure out which one is which.....
    using the gm tech 2 it commands them all off or on by funtion and the EFILive scan tool has them individually
    Nov 2014
Name:	AFM Wiring Diagram1.jpg
    here is the wiring diagram
    Nov 2014
    Nobody has an idea which cylinder is what?
    Sorry I don't know how GM assign the cylinder number to A-D solenoid.
    If you have access to the solenoid wiring, you may be able to probe with a DMM and see which cylinder gets commanded from the V7 scantool.
    Nov 2014
    I mean I can pull the rocker covers off and at idle figure it out I just was curious if anybody knew off the top of their head. But thanks for the replys I'll figure it out eventually when I get working in the car again and when I find out I'll let you guys know :-)
    Locate the wire harness, and if there is a connector, back probe it, otherwise use a piercing probe (and seal the hole immediately afterwards).
    Nov 2014
    I figured it out. A,b,c,d just stands for in which order of the firing order the cylinders are fired in.
    a---b---c---d--
    a=1
    b=7
    c=6
    d=4
    Is this what you found...?
    Oct 2006
    It shows C1,D4,B3,A2 on the diagram. Firing order right?
    2006 Trailblazer
  1. Active Fuel Management controls?
    By XLR8NSS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2011, 10:39 AM
  2. Replies: 2
    Last Post: December 19th, 2008, 09:58 PM
  3. Question about AFM (Active Fuel Management)
    By Hollis1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2008, 03:30 PM
  4. Wiring for Active Fuel Management
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 5th, 2008, 10:28 PM
  5. Disabling Active fuel Management
    By taz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 11:25 AM
