Results 1 to 6 of 6
Thread: Remote AutoCal Setup
    Default Remote AutoCal Setup
    Has anyone ever set up an AutoCal remotely for BBX (BBL)? I'm assuming it is possible. I have a customer that bought a blank one from another dealer. I set up my V2 to BBX for the same pids and controller and looked at the resulting config file list in Explorer- then emailed my customer the files to put in the AutoCal's config tab. When he goes to "Select Pids" he gets a "config required" message. Any ideas?
    Apr 2008
    is the autocal linked to youre v2 or the suppliers?
    stock sucks
    Quote Originally Posted by tokymon View Post
    Thanks for the reply tomymon-
    It was a blank one- and is linked to mine now since he flashed a tune I wrote. I replaced my custom named pid list .txt file with one named "Options" (straight out of my V2) and that got him to the record data screen- but still gets the "config required" message after that.
    Got it working, For anyone that needs to do it in the future-
    1. Build the BBX, Tune and Read options with your V2 in V8 Scan and Tune
    2. Create a new folder where you want to save the config files on your desktop or wherever you can find them
    2. Open EFI Explorer and click on the "config" tab.
    3. Highlight all the config files in the bottom right window, and drag and drop the files into the folder you created in the top of your EFI Explorer window.
    4. Send them to a compressed folder and email them to your customer
    5. Help them unzip the folder to a fresh folder on their desktop, then have them drag and drop the files into their EFI Explorer "config" tab, bottom right window- with the AutoCal connected.
    Nov 2005
    There is another way to this too. We recently added the Quick Setup, which allows you to configure the AutoCal, program BBL, and send tune files in one easy process.
    Open V8 scan and tune, click on BBX, and select the quick setup.
    Process instructions are fully documented under the documentation / tutorial menu on our website..
    Cheers
    Cindy
    Thanks Cindy, page 11 in the newest EFILive AutoCal: Info for Tuners. It does help if you check out the latest docs
  1. Remote Tuning Classes
    By vetteboy2k in forum EFI University
    Last Post: February 7th, 2014, 11:05 AM
  2. $0340 remote flashing 5.9 via autocal... FYI
    By Krazeeun in forum Cummins 5.9L
    Last Post: June 19th, 2012, 04:15 PM
  3. Remote Start configuration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 5th, 2009, 03:24 AM
  4. remote laptop screen ????
    By Delco in forum General
    Last Post: July 11th, 2006, 12:25 AM
