I realize this is an old thread but I thought I would mention that if you are ordering new ones it might be a good idea to get the 8 position terminal blocks (2 of them). If you use the 8 position ones it is much harder to plug them into the incorrect location in the V2. With the 2 position terminals you can actually be off by one pin. If you do this with the wrong set of connections and inputs you can risk damaging the inputs to the V2.
PSS
