Results 1 to 5 of 5
Thread: DSP5 tune package
    Feb 2014
    Default DSP5 tune package
    Im working with an LLY motor with a DSP5 switch. I have some separate tunes i would like to build a DSP5 package for this truck.
    Is a DSP5 tune package 5 separate tunes or 1 tune with 4 different sets of parameters that are switched?
    I have found how to set up the ECM for DSP5 tuning, I have not found the procedures for building the DSP5 package.
    Can someone head me in the proper direction?
    Nov 2005
    DSP5 is one operating system, containing multiple sets of parameters.
    The upgrade document can be found here DSP Upgrade Tutorial - LB7-LLY
    Cheers
    Cindy
    Feb 2014
    I setup DSP5 tune last night, the truck ecm has had a DSP5 tune and switch installed. I am now running a single tune no DSP activated. Question 1: Do i need to reflash ecm with my DSP5 setup before i start to copy tables? Question 2: I have 3 trunes i want to use to create this DSP5 package with. Now i need to copy the tables to correct locations in the DSP5 tune i have started?
    Nov 2005
    Convert your base tune to the DSP operating system, then populate your tables, then flash.
    DSP contains a small subset of available parameters, you'll only be able to copy over the parameters of those 3 tunes provided those tables are DSP parameters.
    Cheers
    Cindy
    Member Dirktdolman's Avatar
    Oct 2014
    I wish they made this option for the LS1B.
  1. SLP L92/LS3 package for LS2
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: August 17th, 2009, 09:11 AM
  2. Whats The Best Package For My Application
    By therock in forum Purchase and Shipping
    Last Post: June 18th, 2009, 10:00 AM
  3. EFI live = Incomplete tuning package!!!!
    By NASABlue in forum General (Petrol, Gas, Ethanol)
    Last Post: February 9th, 2009, 04:56 AM
  4. What EFILive package to get?
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 14th, 2007, 03:49 AM
