I was given a Glow Shift WB 02 sensor to use for tuning and need to know if it is supported by EFI Live. It only has an analog output of 1 - 5v so I figured I could use one of the current supported Pids to log it's data but I don't know which one to use. I figured I would just hook it to the V2 Scanner the same way the AEM was hooked up minus the Serial Out Put. What Pids do I need to log to be able to see it on my lap top scanner? If it helps at all the WB it's self is a Bosch 17025 or 0258017025009 or WO866528. Those are the three numbers on the box.
The last question I have is do I need to ground the output ground wire that is labeled Chassis Ground to a chassis ground and both ports on the V2 or just run them to both ports on the V2 and it will be grounded through the OBDB2 port. Thanks.
