I swapped a 5.3 into my 2001 blazer and am using the factory 4.3 transmission. I used the 4.3 harness and just repined the connectors and added the coil and injector wires. I'm having a problem with the transmission feeling like its locking and unlocking the TC, or its slipping really bad at random times. When I try to go WOT it shifts out of a gear, sending it to the rev limiter, but never shifts into the next gear. At partial throttle it will do the same thing but its not close enough to the rev limiter to reach it before either I let off, or it catches itself. This is the second transmission this is happening with and it came with a bad transmission, so I'm trying to figure out what it could be. Here is the tune and a couple logs I took. I'm not sure what to look for, any help is much appreciated as always. Thanks in advance!
Branden
trans problem 1st log.efi
trans problem 2nd log.efi
Starting point_Trans Script ran.ctz
