Results 1 to 5 of 5
Thread: "CRC-D failed" error message when opening tune
    Nov 2005
    Default "CRC-D failed" error message when opening tune
    Im getting an error message when I try to open a tune. I saved the tune properly obviously, and then next time I tried to open it, EFILive gives me a cyclic redundancy check error message.
    It gives the same message regardless of whether I open the tune in V7.5 or V8.
    Hopefully it can be salvaged...Im going to be kinda screwed here if I cant recover this tune file because its an LML tune, so obviously I cant read the tune back out of the ECM and re-save it that way.....
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Which V8 build version...?
    Nov 2005
    Im not in front of my computer right now, but it's the latest version of V7.5 and V8. I wrote/flashed the tune with the latest version and didn't change anything...just flashed the tune, and went to open it again 2 days later and it said CRC-D failed.
    12.9s @ 108 mph
    Nov 2005
    bump....ideas anyone?
    12.9s @ 108 mph
    Nov 2005
    Ben, do you want to send you tune file over for us to take a look.
    Cindy
  1. Replies: 256
    Last Post: December 7th, 2016, 08:39 AM
  2. LMM "Trailer Brake System Service" message after DSP OS flash.
    By LReiff in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 20th, 2012, 07:12 AM
  3. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
