Results 1 to 10 of 13
Thread: Feature request, custom control over fuel transfer pump relay
    Dec 2014
    Default Feature request, custom control over fuel transfer pump relay
    Request to the EFILive guys (or anyone else who can suggest a better way). I just installed a lift pump on the truck. When I was figuring out my wiring I realized I had a "spare" relay in the stock underhood box labeled fuel pump. Turns out this is for the transfer pump if you have dual tanks. I don't so I figured I'd use the same relay. Already fused, even has "prime" contact in the box so you can manually jumper a wire to run the pump for priming.
    It is factory wired to the ECU and from EFILive I can trigger a DVT to turn the pump on and off. I tried playing with the fuel settings but could not find a way to get the system to normally turn it on.
    The custom digital output with the DSP will allow me to use that digital and swap pins but I'd rather directly use the one already wired (plus I have the other free for future playing). Also most of the input changes are not helpful. Ideal behavior would be:
    • Key-on, prime for 2 seconds and then turn off.
    • Engine running, pump on.
    • Engine stops, pump off.
    Any mechanism to get this feature added or any suggestions on how to control the ECU pin another way? Would be handy for everyone adding a lift pump who does not have a dual tank setup (many of us). Really nice to have all the relays and fuses in stock locations if possible.
    Sorry, we won't be doing any modifications to the DSP OS's for this ECM.
    Mar 2009
    It's not a change to the DSP OS as ALL the DURAMAX ECM's have this capability. ALL DURAMAX's could have came with dual tanks, and have the circuitry and wiring there for a transfer pump. GM used this setup in the vans with a DURAMAX under the hood, so the architecture is there and proven to work. I know if we had this feature, MANY would use it to control there lift pumps. The DSP output is the one he was talking about that dealt with the DSP OS. Since mine is an early engine, I use the 3 wire GM oil pressure switch(but I don't have the prime feature).
    Jan 2015
    Even though the fuel system segments show a different part number
    Dec 2014
    Thanks for the reply. If you guys ever decide to dust this OS off and add this (or help support a one off mod) let me know.
    Just so you don't sit there forever waiting, it will probably never happen, sorry.
    Jul 2013
    too bad, really would be the right way to get it done.
    04 LLY Crew cab
    Complete LBZ intake
    EGR is gone
    PCV delete
    resonator delete
    EFI Live DSP5
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Fuse tap Ignition Fuse and close the hood.
    Dan's Diesel Performance
    Specializing in Duramax and Cummins Diesels
    Building and tuning trucks from daily drivers to full out competition
    www.dansdieselperformance.com
    Jan 2015
    What year and operating system is your truck
    Jan 2015
    After pulling up my fuel system the pid is there for the secondary sender. I wonder if you adjusted the total tank size and set the secondary sending unit up if it would control the transfer pump
  1. Bad ECU? Trailblazer SS, only 5.7 volts at fuel pump relay
    By Praxis in forum Gen IV V8 Specific
    Last Post: October 1st, 2014, 12:32 PM
  2. Using the AC relay output to control a second fuel pump
    By ttls1 in forum Gen IV V8 Specific
    Last Post: December 31st, 2013, 11:13 PM
  3. fuel pump control
    By THEFERMANATOR in forum Duramax LB7
    Last Post: August 9th, 2013, 06:13 AM
  4. fuel pump relay constantly switching
    By steve40 in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:32 PM
  5. Custom OS 3 Bar fuel control questions!
    Last Post: December 1st, 2005, 11:47 AM
