Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: 5.3 twin turbo
    Feb 2014
    Default 5.3 twin turbo
    its a 5.3 with two t3/t4`s 80lb injectors cos3 it runs rich when idling but when it gets into boost around 3600 it starts leaning out gauge shows 16.1 any help would be greatly appreciated here's the tune and a data log
    Feb 2014
    datalog
    Is FPR manifold-referenced or un-referenced...?
    What is measured rail pressure (with FPR reference hose temporarily disconnected)...?
    Feb 2014
    set at 43 raises to 53 unplugged and under boost 64
    So FPR is set to 53 psi with reference hose unplugged...?
    ( an you adjust it to 58 psi (with reference unplugged)...? )
    Did you use 53 psi to calcuare IFR table for "80 lb/hr @ 43 psi" injectors...?
    Feb 2014
    No i used 58
    So FPR is set to 53 psi and IFR in tune uses 59 psi...?
    Feb 2014
    I had it on 58 i turned it down to see if it would lean out the idel
    Post log file of idle.
    Feb 2014
    I put the right numbers in for the ifr for the pressure im running its idles and cruises abut 11.5 to 12 afr I cant figure why it doesn't run the commanded afr"s
  1. Twin Turbo Tuning
    By WisconsinHick1 in forum General (Diesel)
    Last Post: May 12th, 2013, 06:17 PM
  2. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 10:29 PM
  3. Need a Twin Turbo Tune
    By mackattack in forum Duramax LB7
    Last Post: April 20th, 2011, 01:30 AM
  4. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  5. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
