Have you tried taking fuel out of the tune and see if your injector pulse width reduces or stays the same. 2.xxx ms may just be too much fuel with 80lb injectors.
Looks to be staying the same
There are a few threads with people having similar ,I think a cax was needed for a minimum pulse width table.
Would reducing b4005 shorten injector pulse with at idle and cruise
You can try,but I believe without the missing min injector pulse width table if it is in your tune,you will never get below this value. Try doing a search on B9021.
Says not found it has a min injector pulse width its all set at 1.00533
I meant search the forum
how can I add that t0 my os 0407303
