Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: 5.3 twin turbo
  1. #21
    Feb 2014
    os 12587603 the map sensor is a 12614973 for supercharged cobalt but when I put the 2 bar values in for a 2bar it floods it out
  2. #22
    Quote Originally Posted by danny68ss View Post
    Then there's various other problems...
    what does MAP pid show with key-on engine-off...?
  3. #23
    Feb 2014
    Any hope for ill get that when i get home and back on my laptop
  4. #24
    Feb 2014
    14.5 if im looking at the right thing map sae pid
  5. #25
    Feb 2014
    it was wrong map sensor I've worked on the tune following your advice its running much better now not leaning out under boost thank you for pointing me in the right direction here is the tune now and a data log
  6. #26
    Set the scantool units to metric...
    so 14.5 psi would be 100 kPa (much easier)...
  7. #27
    Feb 2014
    Do you see any reason i cant get it to idle and cruise leaner than 12.1 afr
  8. #28
    Log shows commanded AFR 14.17 in CL which matches B3601 in your tune...
    are you seeing AFR 12.1 on your wideband...? I don't see any logged wideband data in your log file.
  9. #29
    Feb 2014
    Yes that is what it shows
  10. #30
    Since you're running SD (MAF-less), your VE table is not correct
    also note that you have LTFT disabled but CL is still enabled... you have to set B4205 to 284F to disable CL
    ( otherwise it will run CL but without applying LTFT since you have LTFT Correction disable (B3801) ).
  1. Twin Turbo Tuning
    By WisconsinHick1 in forum General (Diesel)
    Last Post: May 12th, 2013, 06:17 PM
  2. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 10:29 PM
  3. Need a Twin Turbo Tune
    By mackattack in forum Duramax LB7
    Last Post: April 20th, 2011, 01:30 AM
  4. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  5. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
