Results 1 to 3 of 3
Thread: EFI live lb7 tuning help PLZ!
    Dec 2014
    Default EFI live lb7 tuning help PLZ!
    New to this EFI Live game have one main question. when you want to tune an individual dsp5 switch position, lets say #1, do you just turn your switch to the #1 setting and reflash your ecm or do you have to choose the #1 position in the Flash/Scan V2 program. I am using the hardwired switch setting
    Sep 2006
    When you flash the ECM, it does not matter what position the switch is in...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Dec 2014
    Congrats on the upgrade to EFILive. I also just bought last month and I'm learning the ropes. There is a good tutorial on the process. It should be installed in your v7.5/doc/tutorials/DSP Upgrade Tutorial - LB7-LLY.pdf.
    Basically you will need to open your stock tune and upgrade the OS to DSP5.
    Then save the tune and close.
    Then re-open the tune. When it opens it will now look different. There will be a new set of EFILive specific items you can change. These show the tables that can be modified for each of the 5 tunes.
    Of the 5 tunes one is your basic tune and the next 4 have modifications in this section. You can modify most of the performance tables and the main tables (fuel sensor, etc) are only in the main tune.
    Good luck.
  1. '03 LB7 Invalid Serial Data after EFI Live updates
    By chevyburnout1 in forum Diesel
    Last Post: August 15th, 2013, 01:53 AM
  2. Replies: 7
    Last Post: June 1st, 2012, 03:26 PM
  3. New guy here needs some help with EFI live and my LB7
    By motormadness798 in forum Duramax LB7
    Last Post: February 19th, 2012, 12:50 PM
  4. LB7 EFI LIVE with no real results
    By stevensca25 in forum Duramax LB7
    Last Post: February 5th, 2012, 05:46 AM
  5. newb to efi live info plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2006, 11:59 PM
