I need a little help with tune I have car running good but i feel i am leaving some on table when on motor here is my tune and my data logging
I see that you did not go full throttle the max that you was is 87% check your throttle cable and adjust it if needed or chek if the floor mat is under the gas paddle
what is your intake set up ?
I have the ls3 intake aftermarket ram air kit 90 mm throttle bottle
Log file shows 30 degrees ignition advance at 6000+ rpm with significant load...
and tune shows that your knock gain/rate/limit tables have been zeroed (i.e when knock occurs, you will get zero KR)...
do not run nitrous with this tune.
This is a 2000 t/a with a lq9 370 and ls3 topend 232/234 cam headers intake etc... stock crank forged pistons
That tune is not suitable for nitrous nor for NA.
Also, not mentioned in your other thread, spark timing has been bumped up but we don't know your cam overlap...
Is car a 2000 F-car...?
What mods does engine/car have...?
Man I wonder why I never saw any KR, so I thought I could add timing I will take back down, He had it at 28, so basically I got robbed this tune is terrible
You could put it on a dyno and see where it makes power, even without knock retard you'll hit a point that adding timing does nothing for hp and could even start losing it. You'd be surprised how little timing these engines need. You may not even need 28, most cars like 24-26. As far for 100 shot, you'd probably want to pull a few degrees out which might be dependant on what fuel/plugs you have in it.
Anymore suggestion sir, I really appreciate your help
