Results 1 to 4 of 4
Thread: VT V6 ECU with no BCM, will it connect ?
    Jan 2011
    Default VT V6 ECU with no BCM, will it connect ?
    Some time back I was able to use V4 to connect scan & log my VS V6. Now I have a Toyota Hilux 4WD conversion running the GMH VT V6 engine & ECU.
    It has no BCM & something has been done to the memcal to allow the ECU to runs things like this.
    Now while trying to connect with the EFI V4 to do some scans & hopefully logging, I get the line cannot hear chatter. I did not have this with the VS V6 & my VY V6 when trying to connect.
    Wondering if it is because this set up runs with out the BCM ?
    Cheers
    Deek
    BCM is responsible for all module polling on the VT, with no BCM the bus will be silent until you request something.
    Jan 2011
    Thank you for the reply.
    I am not very good with computers at all. When you say request something, is that a way of connecting to one output at a time ?
    I am hoping to be able to read the rpm & speedo to start with, as I need to fine tune a "Marks Adapters VSS adapter box" as the Hilux has a cable driven speedo.
    Any help being walked through a connection for this set up would be much appreciated.
    Cheers
    Mmm, I don't remember, I never really used V4 sorry, someone else might chime in.
  1. EFiLive and the '07 BCM
    By harascho in forum Tips and tricks
    Last Post: March 13th, 2011, 10:59 PM
  2. Need Help Re-Programming The BCM
    By cwksf in forum General
    Last Post: July 26th, 2009, 03:05 PM
  3. Changing the BCM
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: January 4th, 2009, 06:59 AM
  4. Replies: 19
    Last Post: September 4th, 2008, 04:49 PM
  5. Replies: 4
    Last Post: July 6th, 2008, 04:34 AM
