Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Cant get VX V6 connected to EFILIVE 4
  1. #21
    Jan 2015
    Hi GMPX
    I had taken the vehicle to the Machanic, the tech 11 Scan tool worked well, any idea's on what to do next?
    Mark
  2. #22
    I'm not sure why the VX V6 is not scanning properly with EFILive V4, sorry I'm all out of ideas.
    Unfortunately there is no EFILive tuning option for the VX V6 controller. EFILive V4 is a scan tool only, the vehicles that are supported with V4 can only be scanned and data logged, not tuned.
  3. #23
    Jan 2015
    Hi Blacky
    I eventually have a new cable, I have tried it below is the Data. If you have time can you check it out for me, hope all is well.
    45:32.180: Chatter frame(s):
    45:32.180: 45:32.026: $11,$5C,$FF,$FD,$40,$00,$00,$00,$00,$57
    45:32.180: 45:32.042: $40,$58,$51,$12,$43,$C2
    45:32.180: 45:32.058: $41,$63,$00,$00,$00,$48,$45,$00,$00,$00,$F8,$C5,$0 0,$00,$10,$81,$81
    45:32.180: 45:32.074: $08,$55,$A3
    45:42.487: Start macro: Engine data: DATA
    45:42.485: Synchronising ALDL communications...
    45:42.485: Waiting for heartbeat: $A8,$55,$03
    45:42.485: Waiting for Aldl bus silence of at least 50ms...
    45:42.670: Send: $F5,$57,$01,$00,$B3
    45:42.681: Error: Max232 echo: $D8,$55,$D3 did not match command: $F5,$57,$01,$00,$B3
    45:42.700: Recv: $F5,$57,$01,$00,$B3
    45:42.708: Send: $F5,$57,$01,$00,$B3
    45:42.728: Error: Reply frame checksum failure
    45:42.734: Error: No echo received from MAX232
    45:42.751: Error: Reply frame checksum failure
    45:42.753: Send: $F5,$57,$01,$00,$B3
    45:42.768: Error: Reply frame checksum failure
    45:42.771: Error: No echo received from MAX232
    45:42.782: Error: Reply frame checksum failure
    45:42.790: Send: $F5,$57,$01,$00,$B3
    45:42.919: Com timeout: Expecting frame header byte
    45:42.923: Resuming normal ALDL communications...
    45:42.952: Error: Reply frame checksum failure
    45:42.956: Error: No echo received from MAX232
    45:42.973: Stop macro: Engine data: DATA
    48:11.423: Updating vehicle information...
    48:11.541: Opening COM4 8228,8,N,1
    49:10.804: Updating vehicle information...
    49:10.930: Opening COM4 8228,8,N,1
    49:24.019: Check vehicle interface...
    49:24.025: Waiting for Aldl bus silence of at least 50ms...
    49:24.315: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    49:24.335: Max232 interface detected OK
    49:24.335: Scanning for heartbeat and chatter frames...
    49:24.335: Waiting for Aldl bus silence of at least 50ms...
    49:24.986: Com timeout: Expecting frame header byte
    49:24.999: Heartbeat frame:
    49:24.999: 49:24.750: $A8,$55,$03
    49:24.999: Heartbeat frame is followed by 16ms of silence
    49:24.999: Advisable value for T6 is 8ms
    49:24.999: Chatter frame(s):
    49:24.999: 49:24.766: $20,$55,$8B
    49:24.999: 49:24.783: $D8,$55,$D3
    49:24.999: 49:24.798: $90,$55,$1B
    49:24.999: 49:24.814: $A0,$55,$0B
    49:24.999: 49:24.830: $11,$5C,$FF,$FD,$40,$00,$00,$00,$00,$57
    49:24.999: 49:24.846: $40,$58,$51,$12,$43,$C2
    49:24.999: 49:24.862: $41,$63,$00,$00,$00,$48,$45,$00,$00,$00,$F8,$C5,$0 0,$00,$10,$94,$6E
    49:24.999: 49:24.878: $08,$55,$A3
    49:31.785: Start macro: Engine data: DATA
    49:31.774: Synchronising ALDL communications...
    49:31.774: Waiting for heartbeat: $08,$55,$A3
    49:31.774: Waiting for Aldl bus silence of at least 50ms...
    49:32.243: Com timeout: Expecting frame header byte
    49:32.249: Send: $F7,$57,$01,$00,$B1
    49:32.260: Error: Reply frame checksum failure
    49:32.264: Error: No echo received from MAX232
    49:32.275: Error: Reply frame checksum failure
    49:32.280: Synchronising ALDL communications...
    49:32.280: Waiting for heartbeat: $08,$55,$A3
    49:32.280: Waiting for Aldl bus silence of at least 50ms...
    49:32.896: Send: $F7,$57,$01,$00,$B1
    49:33.008: Com timeout: Data frame truncated: $00,$F8,$C4,$00,$00,$00,$02,$64,$A8,$55,$03,$20,$5 5,$8B,$D8,$55,$D3,$90,$55,$1B,$A0,$55,$0B,$11,$5C, $FF,$FD,$40,$43,$C2,$41,$63,$00,$00,$00,$48,$45,$0 0,$00,$00,$F8,$C5,$00,$00,$10,$51,$B1,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00
    49:33.015: Error: No echo received from MAX232
    49:33.029: Error: Reply frame checksum failure
    49:33.134: Send: $F7,$57,$01,$00,$B1
    49:33.262: Error: Reply frame checksum failure
    49:33.266: Resuming normal ALDL communications...
    49:33.382: Com timeout: Data frame truncated: $55,$D3,$F1,$56,$09,$B0,$90,$55,$1B,$A0,$55,$0B,$1 1,$5C,$FF,$FD,$40,$00,$00,$00,$00,$57,$40,$58,$51, $12,$43,$C2,$41,$63,$00,$00,$00,$48,$45,$00,$00,$0 0,$F8,$C5,$00,$00,$10,$46,$BC,$08,$55,$A3,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00
    49:33.386: Error: No echo received from MAX232
    49:33.507: Com timeout: Expecting frame header byte
    49:33.511: Stop macro: Engine data: DATA
    49:41.470: Start macro: Engine data: DATA
    49:41.477: Synchronising ALDL communications...
    49:41.477: Waiting for heartbeat: $08,$55,$A3
    49:41.477: Waiting for Aldl bus silence of at least 50ms...
    49:42.015: Com timeout: Expecting frame header byte
    49:42.022: Send: $F7,$57,$01,$00,$B1
    49:42.033: Error: Reply frame checksum failure
    49:42.037: Error: No echo received from MAX232
    49:42.048: Error: Reply frame checksum failure
    49:42.052: Synchronising ALDL communications...
    49:42.052: Waiting for heartbeat: $08,$55,$A3
    49:42.052: Waiting for Aldl bus silence of at least 50ms...
    49:42.665: Send: $F7,$57,$01,$00,$B1
    49:42.681: Error: Reply frame checksum failure
    49:42.689: Error: No echo received from MAX232
    49:42.700: Error: Reply frame checksum failure
    49:42.811: Send: $F7,$57,$01,$00,$B1
    49:42.825: Error: Reply frame checksum failure
    49:42.829: Error: No echo received from MAX232
    49:42.951: Com timeout: Data frame truncated: $74,$F7,$57,$01,$00,$B1,$08,$55,$A3,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00
    49:42.953: Resuming normal ALDL communications...
    49:42.987: Stop macro: Engine data: DATA
    49:48.256: Start macro: Engine data and DTCs: DATADTC
    49:48.263: Synchronising ALDL communications...
    49:48.263: Waiting for heartbeat: $08,$55,$A3
    49:48.263: Waiting for Aldl bus silence of at least 50ms...
    49:48.635: Com timeout: Expecting frame header byte
    49:48.642: Send: $F7,$57,$01,$01,$B0
    49:48.661: Error: Reply frame checksum failure
    49:48.667: Error: No echo received from MAX232
    49:48.775: Com timeout: Data frame truncated: $01,$B0,$A8,$55,$03,$20,$55,$8B,$D8,$55,$D3,$90,$5 5,$1B,$A0,$55,$0B,$11,$5C,$FF,$FD,$40,$00,$00,$00, $00,$57,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00
    49:48.778: Synchronising ALDL communications...
    49:48.778: Waiting for heartbeat: $08,$55,$A3
    49:48.778: Waiting for Aldl bus silence of at least 50ms...
    49:49.274: Com timeout: Expecting frame header byte
    49:49.281: Send: $F7,$57,$01,$00,$B1
    49:49.291: Error: Max232 echo: $40,$58,$51,$12,$43,$C2 did not match command: $F7,$57,$01,$00,$B1
    49:49.319: Error: Reply frame checksum failure
    49:49.433: Synchronising ALDL communications...
    49:49.433: Waiting for heartbeat: $08,$55,$A3
    49:49.433: Waiting for Aldl bus silence of at least 50ms...
    49:49.899: Com timeout: Expecting frame header byte
    49:49.905: Send: $F7,$57,$01,$00,$B1
    49:49.916: Error: Max232 echo: $40,$58,$51,$12,$43,$C2 did not match command: $F7,$57,$01,$00,$B1
    49:49.930: Error: Reply frame checksum failure
    49:49.935: Stop macro: Engine data and DTCs: DATADTC
    50:20.990: Opening COM4 8228,8,N,1
    50:29.924: Check vehicle interface...
    50:29.927: Interface not checked because "Max232 echo" is not set. (see Com port settings)
    50:29.927: Scanning for heartbeat and chatter frames...
    50:29.927: Waiting for Aldl bus silence of at least 50ms...
    50:30.318: Com timeout: Expecting frame header byte
    50:30.325: Heartbeat frame:
    50:30.325: 50:30.139: $A0,$55,$0B
    50:30.325: Heartbeat frame is followed by 32ms of silence
    50:30.325: Advisable value for T6 is 16ms
    50:30.325: Chatter frame(s):
    50:30.325: 50:30.171: $11,$5C,$FF,$FD,$40,$00,$00,$00,$00,$57
    50:30.325: 50:30.187: $40,$58,$51,$12,$43,$C2
    50:30.325: 50:30.203: $41,$63,$00,$00,$00,$48,$45,$00,$00,$00,$F8,$C5,$0 0,$00,$10,$50,$B2
    50:30.325: 50:30.219: $08,$55,$A3
    50:35.089: Start macro: Engine data: DATA
    50:35.079: Synchronising ALDL communications...
    50:35.079: Waiting for heartbeat: $08,$55,$A3
    50:35.079: Waiting for Aldl bus silence of at least 50ms...
    50:35.582: Send: $F7,$57,$01,$00,$B1
    50:35.598: Recv: $F7,$57,$01,$00,$B1
    50:35.606: Send: $F7,$57,$01,$00,$B1
    50:35.616: Error: Reply frame checksum failure
    50:35.620: Send: $F7,$57,$01,$00,$B1
    50:35.632: Error: Reply frame checksum failure
    50:35.635: Send: $F7,$57,$01,$00,$B1
    50:35.721: Error: Reply frame checksum failure
    50:35.725: Resuming normal ALDL communications...
    50:35.845: Com timeout: Data frame truncated: $FC,$F1,$56,$09,$B0,$A8,$55,$03,$20,$55,$8B,$D8,$5 5,$D3,$90,$55,$1B,$A0,$55,$0B,$11,$5C,$FF,$FD,$40, $00,$00,$00,$00,$57,$40,$58,$51,$12,$43,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00
    50:35.850: Stop macro: Engine data: DATA
    50:40.693: Start macro: Engine data and DTCs: DATADTC
    50:40.710: Synchronising ALDL communications...
    50:40.710: Waiting for heartbeat: $08,$55,$A3
    50:40.710: Waiting for Aldl bus silence of at least 50ms...
    50:41.270: Send: $F7,$57,$01,$01,$B0
    50:41.286: Recv: $F7,$57,$01,$01,$B0
    50:41.292: Send: $F7,$57,$01,$00,$B1
    50:41.319: Error: Reply frame checksum failure
    50:41.325: Send: $F7,$57,$01,$00,$B1
    50:41.336: Error: Reply frame checksum failure
    50:41.339: Send: $F7,$57,$01,$00,$B1
    50:41.444: Com timeout: Data frame truncated: $40,$F7,$57,$01,$00,$B1,$F7,$A1,$01,$00,$00,$00,$0 0,$56,$61,$79,$5D,$00,$00,$00,$00,$17,$00,$65,$00, $66,$00,$09,$50,$0C,$00,$80,$00,$80,$00,$00,$00,$9 3,$7B,$FF,$80,$80,$4E,$00,$00,$70,$71,$00,$00,$00, $00,$5F,$00,$00,$97,$A4,$F7,$FC,$00,$00,$00,$00,$0 0,$00,$00,$00,$80,$80,$A6,$00,$FF,$C5,$4F,$00,$02, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00
    50:41.448: Resuming normal ALDL communications...
    50:41.459: Error: Reply frame checksum failure
    50:41.463: Stop macro: Engine data and DTCs: DATADTC
    51:55.114: Check vehicle interface...
    51:55.117: Interface not checked because "Max232 echo" is not set. (see Com port settings)
    51:55.117: Scanning for heartbeat and chatter frames...
    51:55.117: Waiting for Aldl bus silence of at least 50ms...
    51:55.684: Com timeout: Expecting frame header byte
    51:55.692: Heartbeat frame:
    51:55.692: 51:55.501: $90,$55,$1B
    51:55.692: Heartbeat frame is followed by 17ms of silence
    51:55.692: Advisable value for T6 is 8ms
    51:55.692: Chatter frame(s):
    51:55.692: 51:55.517: $A0,$55,$0B
    51:55.692: 51:55.533: $11,$5C,$FF,$FD,$40,$00,$00,$00,$00,$57
    51:55.692: 51:55.549: $40,$58,$51,$12,$43,$C2
    51:55.692: 51:55.565: $41,$63,$00,$00,$00,$48,$45,$00,$00,$00,$F8,$C5,$0 0,$00,$10,$50,$B2
    51:55.692: 51:55.581: $08,$55,$A3
    52:02.787: Start macro: Engine data: DATA
    52:02.782: Synchronising ALDL communications...
    52:02.782: Waiting for heartbeat: $08,$55,$A3
    52:02.782: Waiting for Aldl bus silence of at least 50ms...
    52:03.155: Send: $F7,$57,$01,$00,$B1
    52:03.171: Recv: $F7,$57,$01,$00,$B1
    52:03.178: Send: $F7,$57,$01,$00,$B1
    52:03.189: Error: Reply frame checksum failure
    52:03.194: Send: $F7,$57,$01,$00,$B1
    52:03.205: Error: Reply frame checksum failure
    52:03.208: Send: $F7,$57,$01,$00,$B1
    52:03.294: Error: Reply frame checksum failure
    52:03.298: Resuming normal ALDL communications...
    52:03.414: Com timeout: Data frame truncated: $27,$DB,$F1,$56,$09,$B0,$A8,$55,$03,$20,$55,$8B,$D 8,$55,$D3,$90,$55,$1B,$A0,$55,$0B,$11,$5C,$FF,$FD, $40,$00,$00,$00,$00,$57,$40,$58,$51,$43,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00, $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00
    52:03.419: Stop macro: Engine data: DATA
    Mark
  4. #24
    Hi Mark,
    The good news is, the new cable looks lik eit is working better than the first one, the bad news is that something is still not working properly.
    Can you do two thigs for me, please?
    1. Send me the *.xml file that you are using. I.e. the file will most likely be: \Program Files (x86)\EFILive\V4\Vehicle data streams\gmh-vx6.xml. Please zip the file because sometimes email systems will mess with the content of an xml file attachment.
    2. Connect everything up and select the "Display ALDL Chatter(Ctrl+L)" option. Allow it to run for at least 30 seconds, then copy all the text text that was displayed and paste it into this thread.
  1. V2 Not Working/ or connected
    By Mr Baadboy in forum Diesel
    Last Post: October 30th, 2013, 07:09 PM
  2. V2 will not stay connected to my computer
    By Burnt_Bizcut00 in forum FlashScan V2
    Last Post: February 17th, 2013, 03:41 AM
  3. No device connected?
    By Mtnbike4522 in forum FlashScan V2
    Last Post: January 9th, 2011, 08:37 AM
  4. Not Connected message
    By 920codyroad in forum Gen III V8 Specific
    Last Post: December 15th, 2009, 05:45 PM
Tags for this Thread
