Just an FYI -- whenever you do a firmware, software update it is best to "Format Cofig" file and rewrite that file with new Config file data.
In the past it has caused some problems with reading and flashing PCMs for me.
Here is how to do that:
"Go to "EFILive Explorer" with controller plugged into desktop/laptop, click on tab marked "F9: Config Files" and "Format Config", then close that and open EFILive Scan and Tune>F5: BBX and do the setup again> "Program" (make sure the percentage to be written is under or at 100%, if not remove some unused PCM parameters), "Config file" gets rewritten. Try again."
