2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
The stock values may not necessarily be sane.
Make sure that the MPH values do not exceed the maximum RPM for each gear (when you click on an MPH cell, the bottom of the tunetool shows the corresponding RPM for each gear (based on the Speedo segment axle ratio and tire diameter)(make sure you look at the right one)).If I understand this correctly, the modified numbers should look something like this.
Usually I make the downshift MPH at least 5 MPH lower than the upshift MPH.
WOT downshift requires both WOT MPH and WOT RPM to be met (that's just how the PCM does it)... usually you set one lower than needed, so the other one is the trigger.What is the purpose to set a downshift speed for WOT?
The maximum RPM is the rev limiter (B3303, B5401), or the RPM corresponding to the vehicle speed limiter (H0109, H0111)...
or it can simply be that you want each shift to be at some particular RPM (say at peak torque), so they won't necessarily be the rev limiter RPM
( for example, your tach redline might be at 6000 rpm, your rev limiter may be set at 6200 rpm, but you want the shift to occur at/below 5800 rpm, for example ).
No, the shift RPM you showed in the pic is part of a 2 component WOT shift trigger...
( WOT RPM and WOT MPH ) ( at WOT both have to be met for a WOT upshift )
the WOT MPH is not necessarily the maximum RPM.
Is there a way to convert all the KPH to MPH in my tune? I know I can do it in a PID but do not know how in a tune.
( B5401 kicks in only if you have DBW electronic throttle )
