See post #2 here: Part-throttle-shift-table-conversion
2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
YOU ROCK, thank you
Yes, they should be the same values.
The 100% values in the PT tables should be the same as the WOT MPH parameters.
Joe
Is there an easy way to enter the tire diameter?
Is that a correction just for the speedo or does it effect all the shift settings? I was thinking it was just the speedo. Which would mean I would have to change all my shift points and such if I were to change tire diameter.
