Results 1 to 3 of 3
Thread: Pulling at light in Gear
    Jun 2003
    Default Pulling at light in Gear
    Ok, I can not think of where to look why my car is pulling away at a stop. Just letting up off the brake and its just up and running.
    Idle is at 800.
    I know its an agressive cam, and I have not worked on anything more then a TR224. Is this normal?
    I ordered a Crane Cams vacuum canister to help with that problem, would this also cause it to want to just go on its own without giving it gas?
    Jun 2005
    Stock stall? That's usually part of the reason they suggest aftermarket stalls with bigger cams....because they require a higher idle. Not to mention, putting it in gear must be fun if it's a stock stall.
    Jun 2003
    Its an A4 an not really that bad, just wondering why its pulling. If thats expected with the stock stall then no problem I will upgrade that later.
    The idle is just fine at 750-800 and not really doing bad at all.
  1. Service brake system w/ABS light and Parking Light on
    By mshirshe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 13th, 2010, 03:32 AM
  2. Car is pulling timing
    Last Post: February 27th, 2010, 04:55 AM
  3. Gear Swap and now service brake system/abs light
    By exploder in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2009, 09:04 AM
  4. Pulling vaccum at WOT
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: September 30th, 2007, 02:55 PM
  5. Pulling timing
    Last Post: August 27th, 2006, 06:40 AM
