Results 1 to 5 of 5
Thread: Speed Density Charge Temp Blend Factor (MAF g/sec)
    Feb 2007
    Default Speed Density Charge Temp Blend Factor (MAF g/sec)
    I was just wondering when in speed density (MAF disabled), how does the PCM look up the charge temp factor based on MAF g/sec?
    I thought it uses DYNAIR g/s...
    Feb 2007
    I'm just thinking there's something wrong with that? Looking to the table its trying to correctly reference, its in a feed back loop?
    Hmmm, let me think about it... (I'm looking in an LS1B file... can you post your E40 file).
    PCM uses airflow g/s to lookup the factor to skew the air temperature toward ECT...
    and then temperature is used to lookup VE to calculate DYNAIR...
    it looks like a feedback loop... this could be stable (converges) or unstable (diverges) depending on the blend factor and the filter...
    hmmm, interesting... requires a few experiments.
  1. Charge Temp Blending, no MAF
    By 12_Square in forum Gen III V8 Specific
    Last Post: April 16th, 2014, 03:04 AM
  2. Harrop Hurricane MAF vs Speed Density
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2013, 04:45 AM
  3. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  4. Speed Density Charge Temperature Blending (E40)
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: June 28th, 2008, 04:36 PM
  5. charge temp blending
    By 5.7ute in forum Custom Operating Systems
    Last Post: February 8th, 2007, 04:07 PM
