Results 1 to 7 of 7
Thread: Segments all match except speedo... thoughts?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Segments all match except speedo... thoughts?
    Here's the tune file I have for a 2011 GMC.... It's the closest one I can find, I literally have none that match the speedometer segment for his vin. The original speedometer segment # was 12646357. What are your thoughts? Should they be compatible?
    Boot Software 12646251
    Slave Operating System 12646250
    Main Operating System 12646249
    Engine 12655862
    Speedometer 12646359
    System 12655886
    Fuel System 12646324
    Engine Diagnostic 12655870
    Engine Operation 12655864
    Thanks!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Dec 2005
    Just change the tire size in the Cal to match what you need, it will most likely get you by.
    www.mscservices.net
    Jun 2008
    Thanks Tony
    Dec 2005
    All of the stock calibrations I have looked at the speedo segment is a different tire size is all I have determined it to be.
    18" , 20" dually's, etc all have a different tire size
    www.mscservices.net
    Jan 2015
    Quote Originally Posted by LBZoom View Post
    Engine 12655862
    System 12655886
    Thanks!
    Did you find the file you were looking for? If not i can share the one i have. It has the speedo you want and all the others.
    08 LMM CC Dually
    Canada
    Jan 2015
    I have it. Let me know if you still need it..
    08 LMM CC Dually
    Canada
    Jun 2008
    Thanks man, the speedometer segment worked for us, good to go! Thanks again!
  1. copying trans segments
    By smellyflange in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2014, 11:37 AM
  2. Please help with changing 4L60e Trans segments to 4L80e
    By ttls1 in forum Gen III V8 Specific
    Last Post: April 15th, 2013, 08:31 AM
  3. one or more invalid checksum segments
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2010, 05:22 AM
  4. E38 w/ No transmission Segments
    By Shupe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 14th, 2008, 01:32 AM
  5. Fuel Segments for 1998 T/A
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 14th, 2008, 05:12 AM
