Results 1 to 9 of 9
Thread: Script exited with code $0101: No data received
    Dec 2007
    Default Script exited with code $0101: No data received
    Truck was giving me all sorts of odd codes upon initial flash. Finally got it to take a DSP5 file then went to make changes via a Cal flash same issue wouldn't take so I went to start it and no start. ECM is working I can hear it power on/off. I am also able to clear codes. What can I try...
    Dec 2005
    Its probably a brick, that is the bad code.
    Paul or Ross would probably agree.
    If you cannot pull a VIN# and ECM SN# and get no response using the get calibration info then its a brick most likely
    www.mscservices.net
    Dec 2007
    Can it brick by doing a Cal flash?
    Dec 2005
    Try to read it out, EFI-Live software will alert you if the Cal is bad, try to read it and if the ECM won't boot to read then that is another bad sign.
    Usually a CAL Flash won't Brick it, but a Cal flash on an LB7 just alters the base tune and not the DSP5 tunes
    www.mscservices.net
    Dec 2007
    It won't read the ECM.
    Dec 2005
    Its most likely bricked, only way to fix it if you cannot pull any codes, or get any info is a Flash Chip replacement.
    I lost count how many ecms I have gotten back as cores that were bricked over the last 9 years.
    I have not bricked one yet, but plenty of times they brick themselves.
    www.mscservices.net
    Would you mind Emailing your tune to support@efilive.com with a link to this thread.
    Thanks,
    Dec 2007
    Thanks,
    I will do it in about 45 minutes
    It is 7pm in NZ....don't rush
  1. Replies: 4
    Last Post: September 3rd, 2013, 07:18 AM
  2. Autocal Read Error $0101 No data received
    By firehawk in forum AutoCal
    Last Post: April 14th, 2013, 09:36 PM
  3. Replies: 8
    Last Post: April 9th, 2013, 12:00 PM
  4. Replies: 2
    Last Post: December 31st, 2012, 10:11 PM
  5. Replies: 7
    Last Post: December 31st, 2012, 10:52 AM
