I haven't found anything in a search - I have a calc_pid.txt file that has 6 PIDs in it. The file works fine with 5 PIDS in it (i.e., only going up to F005). Regardless of what PID I enter in or above slot F006, I get a "Slot F006 not found" error when I open the scanner. Let me know if you can see any issue in the calc_pid file, pasted below.
Thanks.
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
V 0.0 5.0 .4 "{EXT.AD1}"
psi 0.0 30.0 .1 "(7.5*{EXT.AD1})-3.75"
*CLC-00-002
V 0.0 5.0 .4 "{EXT.AD21}"
*CLC-00-003
V 0.0 5.0 .4 "{EXT.AD3}"
F -4.0 302.0 .0 "-6.51*pow({EXT.AD3},3)+54.6*pow({EXT.AD3},2)-180*{EXT.AD3}+326"
*CLC-00-004
V 0.0 5.0 .4 "{EXT.AD4}"
F -4.0 302.0 .0 "-6.51*pow({EXT.AD4},3)+54.6*pow({EXT.AD4},2)-180*{EXT.AD4}+326"
*CLC-00-005
F 0.0 1800.0 .0 "{EXT.TEMP1}"
*CLC-00-006
F 0.0 1800.0 .0 "{EXT.TEMP2}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.Pre_Fuel_Psi F001 CLC-00-001 "psi" Fuel "Pre-Filter Fuel Psi"
CALC.Post_Fuel_Psi F002 CLC-00-002 "psi" Fuel "Post-Filter Fuel Psi"
CALC.Pre_Fuel_Temp F003 CLC-00-003 "F" Fuel "Pre-Cooler Fuel Temp"
CALC.Post_Fuel_Temp F004 CLC-00-004 "F" Fuel "Post-Cooler Fuel Temp"
CALC.EGT F005 CLC-00-005 "F" Fuel "EGT"
CALC.Oil Temp F006 CLC-00-006 "F" Fuel "Oil Temp"
