Results 1 to 2 of 2
Thread: 2004 lly p0700
    Jan 2015
    Default 2004 lly p0700
    My truck just set off a p0700 code after I put superchips in it any idea y I would do this ? And I am getting efi live on sat but we where haveing problems with it if u read my last two forms post thanks any advice would help
    Mar 2009
    P0700 means the trans is calling for the malfunction indicator lamp to come on. SOunds liek you got on it to hard before the trans had learned, and limped it. You will need a better scanner such as EFILIVE to see what the actual trouble code is in the TCM as most scanners do not talk to the ALLISON TCM.
  1. 2004 lly PCM locked
    By bman in forum Duramax LLY
    Last Post: January 13th, 2015, 07:18 PM
  2. 2004.5 LLY can I use 2006 LLY tunes?
    By Badass_chris in forum Duramax LLY
    Last Post: October 22nd, 2012, 04:16 AM
  3. 2004.5 LLY EGR Block???'s
    By GAMEOVER in forum Duramax LLY
    Last Post: February 20th, 2011, 11:38 AM
  4. 2004.5 LLY limping trans?
    By Mr.Blister007 in forum Duramax LLY
    Last Post: September 1st, 2010, 12:34 PM
  5. 2004 LLY Dual alternators
    By s10mods in forum Duramax LLY
    Last Post: March 29th, 2009, 01:45 PM
