2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
Good news was able to data log all the way to work today. So now I have multiple files to start looking at. Deff getting excited to start doing this again since its working the way it should!!. Big shout out to Les for helping me.
It looks to me like 50mpa of fuel pressure is the lowest you recorded. Which is about 7250psi. So all that is saying it's that your fuel pressure never went below that number.
50mpa is your fuel pressure at idle. The 50mpa column of your fuel pressure actual populated the cells in that column. You can see that the 50mpa column was only populated at 0 to 35mm3 which is light to no throttle conditions.
oh ok now it makes sense. So mm3 is throttle in this case. Now it makes sense on why it starts at 50mpa. I thought I had something wrong.
ok well I just finished creating my csp tunes and I have them all done. I went flashed the truck but only the v2 switching works the csp5 switch doesnt work. Do you have to enable this with csp tune? Also on start up I increased the high idle speed to 1100 but when I gave it some gas the rpms spiked and wouldnt drop untill I switched into another tune with the v2.
That is just how the factory set it up, we are showing what they have, that isn't an EFILive decision you see there. I guess they wanted to accommodate all possible scenarios.
Should make no difference, both should work (is your CSP5 switch a genuine 'approved' by EFILive)?
No, when you do the conversion to CSP5 everything is automatically enabled.
I don't know exactly what it is, it may have just been a pressure 'spike' when you lifted causing a back up of pressure that pushed it out to that cell.
