Results 1 to 10 of 12
Thread: LMM Dual tank settings
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default LMM Dual tank settings
    Hey guys,
    Does anyone have a screen shot or table of the settings for an LMM with factory dual tanks? I flashed a dually truck for a customer and didn't know it had dual tanks until afterward.
    Or does the truck only have a sender in one tank?
    Thanks!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Dec 2005
    Did you use the file from the truck ?
    www.mscservices.net
    Jun 2008
    no, rookie mistake lol, it was a flatbed dually, I just flashed in a cal for a 34 gallon long bed, single tank.
    Dec 2012
    1268594 OS, factory dual tank cab and chassis. If you need the file a can send it.
    2005 Cummins - EFILive Conversion - S474 single - 1325hp on the spray.
    Jun 2008
    Thanks a million, I'll make sure I convert the liters to gallons haha. Thanks again!
    Jun 2008
    Can you post a shot of the fuel scale, or email me the file? punisherperf@gmail.com
    Thanks!
    Dec 2012
    Yes but I can't till later tonight
    Mar 2009
    You NEED the dual tank OS to make it work. You can do the tables and make the gauge work, but without the correct fuel system segment it won't work the transfer pump to move fuel from the rear tank to the front. If it has dual tanks, then it was a cab and chassis model, unless he added the 2nd tank. You will NEED the correct base file to make it work correctly though, no way around it.
    May 2014
    THEFERMANATOR is correct. Dual tank settings will not fix your problem. Even identical OS numbers is not a guarantee that every thing such as fuel level will work correctly. EFILive will compare OS with the identical numbers but not all parameters are covered by this comparison. You will need the proper base file.
    Jun 2008
    Hey guys,
    On this Dual tank LMM, He's still getting weird issues with the fuel gauge, it can show a 1/4 tank until you shut the key off and turn it back on, then it will jump to 3/4 tank.... I'm not sure if it's OS related or he's got electrical issues elsewhere. Does anyone have a stock tune for a dual tank LMM, Cab & Chassis I believe from the vin....with the matching fuel calibration segment number 12628610?
    Here's the vin: 1GBJK796X9E101369
  1. LMM turbo brake RPM settings
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 20th, 2012, 04:32 AM
  2. Took the GTO out to fill up the tank.....
    By 10secvette in forum Gen IV V8 Specific
    Last Post: July 24th, 2009, 12:08 PM
  3. changed fuel tank size
    By evilspyder66 in forum General (Diesel)
    Last Post: March 29th, 2009, 01:33 PM
  4. 159 litre fuel tank???
    Last Post: April 8th, 2007, 09:49 AM
  5. Fuel Tank Parameters
    Last Post: April 7th, 2007, 11:57 PM
